7200 Not working
Feb 9th, 2008
My Router cisco 7200 series is haveing problem. When i finish the config on the g0/1 service as my Outside interface with a public Ip address and g0/2 ad inside with a private Ip, the router hangs and I change the g0/2 to g0/3 and it's still the same problem. when pinging it will reply while loading the IOS file but immediately it finish loading it will time out. Please Help me give a lasting solution to this. Thank You
paolo bevilacqua Sat, 02/09/2008 - 04:16
  • Hall of Fame,
    Founding Member
Which exact IOS do you have ?
paolo bevilacqua Sun, 02/10/2008 - 11:54
  • Hall of Fame,
    Founding Member
That can be sw bug, if you are ok with 12.2 pls upgrade, I suggest 12.2(46a).
enetstechnologies Sun, 02/10/2008 - 12:43
Thanks please Can You help me with a direct link were i can get that downloaded. Thank you.
