backup interface
Feb 9th, 2008
Is it possible to have a fastethernet interface as a backup of more than one serial lines on a 7507 router ?
Goutam Sanyal Sat, 02/09/2008 - 01:51
If I assume that you want FastEthernet as a backup interface of Serial so it is possible. Also its depends how your network is designed.
Router(config)#inty ser 0/0/0
Router(config-if)#backup interface fastEthernet ?
<0-0> FastEthernet interface number
pls rate if it works.
kon_salev Sat, 02/09/2008 - 02:16
I use a 7507 with 15 serial lines and a second 7507 with 5 adsl-vpn lines. The two routers are connected together with fastethernet. I want to use the fastethenet for backup of all 15 seials.
Richard Burts Sat, 02/09/2008 - 05:38
While it may work for one interface I believe that trying to use any interface as backup for more than 1 interface is a problem. This is because the backup interface is put into a special state while the primary is up and the backup only becomes active when the primary is down. So if the FastEthernet is backup for serial 1 and 2 and serial 1 goes down I believe that the FastEthernet will not activate until both interfaces go down.
Perhaps an alternative might be to create a trunk on the FastEthernet with VLAN subinterfaces going over the trunk. Then you could use a subinterface as backup for the serial.
