Can't estabilish calls using g729
Feb 9th, 2008
I'm trying to establish connection between phones using g729 but unable to do so. g711u codec works just fine. In log I don't see any reason why it shouldn't establish it.
Overall Rating: 3 (1 ratings)
nikolay-shopik Sat, 02/09/2008 - 03:52
yes I do.
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
voice register pool 2
id mac 0000.0000.0000
number 1 dn 2
username XXX password XXX
voice register pool 4
id mac 001A.2FA6.F21E
number 1 dn 4
dtmf-relay sip-notify
voice-class codec 1
pool 2 is initiator of connection I've removed voice-call codec to force use only g729
Paolo Bevilacqua Sat, 02/09/2008 - 16:31
On the trace you sent, cause code 65 is bearer capability not implemented, meaning codec mismatch.
Take a trace again with the proper voice-class set on both voice register pool, and send it here with the configuration.
nikolay-shopik Sun, 02/10/2008 - 02:28
Same reason cause=65, its running on: c2800nm-advipservicesk9-mz.124-15.T3.bin
Currently I have some problems with testing because NAT incorrectly translate sip headers(IOS bug), when have two outside interfaces.
I will continue testing on site tomorrow Monday.
nikolay-shopik Mon, 02/11/2008 - 05:56
I choice g729r8 codec alone on voice register pool. And its clear cisco don't like some settings of g729 from my third party phone.
nikolay-shopik Mon, 02/11/2008 - 11:17
yes both phones registered fine, I see no problem in registration when check logs. Tomorrow we will receive bunch of 7911 phones, hope this help isolate problem.
