UC 500 BRI settings
Feb 9th, 2008
I've bin trying to get KPN multi ISDN2 linked together( 2 NT cases) under 1 number working on a UC500 with the follwing settings
interface BRI0/1/1
description ISDN-BRI CONNECTION TO KPN
no ip address
isdn switch-type basic-net3
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
trunk-group ISDN-LINES
the reply i get form the UC500 is
Feb 9 16:37:17.374: BRI0/1/1: In state F7, Received code unknown code
Feb 9 16:37:17.374: BRI0/1/1: In state F7, Received code Activation Indication with Priority to 8, Info 4 received
Feb 9 16:37:17.374: BRI0/1/1 : do nothing
I tryied several settings nothing works
What i'm i doing wrong?
Greetings Andy
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Sat, 02/09/2008 - 09:07
  • Hall of Fame,
    Founding Member
hi, static-tei 0 should be right, but remove "isdn tei-negotiation"
Important, please upgrade to XW5 because previous versions are very buggy.
If still trouble, do "isdn test call int bri0/1/1 number 123" with debug isdn q921 and q931 active. Post output here.
hotrot_net Sat, 02/09/2008 - 09:16
XW5 already onboard en runnig
after making changes en putting to test i get this
UC520#isdn test call int BRI0/1/1 number 123
% Invalid input detected at '^' marker.
Oops got this
Feb 9 17:19:27.158: ISDN BR0/1/1 **ERROR**: host_disconnect_ack: Unfound B-channel on Disconnect_Ack call id 0x800F
Paolo Bevilacqua Sat, 02/09/2008 - 10:22
  • Hall of Fame,
    Founding Member
Sorry there is no "number" in isdn test call. Get the debug isdn q931 now. Just try any call in or out. Place the two itnerface in trunk group to get everything easier.
hotrot_net Sat, 02/09/2008 - 10:34
inbound won't even work with the test call i get this outbound i get this
Feb 9 18:32:29.451: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 90492540770
Feb 9 18:32:29.451: ISDN BR0/1/1 Q931: TX -> SETUP pd = 8 callref = 0x05
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Called Party Number i = 0x80, '90492540770'
Plan:Unknown, Type:Unknown
Sending Complete
Feb 9 18:32:29.883: ISDN BR0/1/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x85
Cause i = 0x8281 - Unallocated/unassigned number
Feb 9 18:32:29.887: ISDN BR0/1/1 **ERROR**: host_disconnect_ack: Call rejected cause Unallocated/unassigned number(0x1) call id 0x8005
Feb 9 18:32:39.999: ISDN BR0/1/1 Q931: Ux_DLRelInd: DL_REL_IND received from L2
inbound i get this
eb 9 18:34:32.579: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8 callref = 0x24
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Channel ID i = 0x81
Preferred, B1
Calling Party Number i = 0x2183, '625030456'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '493440075'
Feb 9 18:34:32.591: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8 callref = 0xA4
Channel ID i = 0x89
Exclusive, B1
Feb 9 18:34:32.607: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8 callref = 0xA4
Cause i = 0x8081 - Unallocated/unassigned number
Feb 9 18:34:32.983: ISDN BR0/1/1 Q931: RX <- RELEASE pd = 8 callref = 0x24
Feb 9 18:34:32.983: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA4
Paolo Bevilacqua Sat, 02/09/2008 - 10:40
  • Hall of Fame,
    Founding Member
Hi, outbound you are calling:
90492540770
What is the correct number ? check destionan-pattern and digit strip
Inbound, if you have did, you need a translation-rule or dialplan pattern command. If you don't have did, place a translation-profile to translate to the number you want, uner trunk group.
hotrot_net Sat, 02/09/2008 - 10:47
so its working both inbound and outboud now??
i did reload it did not set up any dialplan pattern or DID yet .
you might noticed that i'm novice at the UC520 this is the first one I palced at a client. wont be the last..!! DO
Paolo Bevilacqua Sat, 02/09/2008 - 10:49
  • Hall of Fame,
    Founding Member
Yes it is. Look at the trace it's easy to read. You just need to get the numbers right now.
Paolo Bevilacqua Sat, 02/09/2008 - 11:05
  • Hall of Fame,
    Founding Member
You're welcome. Please remember to rate useful posts with the scrollbox below!
