Switchs and Routers to provide VOIP solutions.
Answered Question
Feb 9th, 2008
Witch is the best option in Cisco switchs and routers catalogue to a network with 50 users to implement a VOIP solution?
Best regards
Gustavo Sousa
Correct Answer by paolo bevilacqua about 9 years 1 month ago
A 2821 with CME will support up to 52 IP phones, doing a very complete PBX, without the need for external servers or anything else.
Get ISDN for the telco lines, do not use analog lines that are alway a source of trouble. Get a CUE in AIM or NM form if users want voice mail.
For the switch, if you can afford the price, get a a 3560 or 3750 48 ports with PoE. If you can't, get two WS-CE500 24 ports, again with PoE.
Choose the phones as you like better, a good choice is the 7931 that has many buttons and a good lighted display.
That to give you an idea of what you need.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sat, 02/09/2008 - 13:16
  • Hall of Fame,
    Founding Member
gustavosousa Sun, 02/10/2008 - 10:49
Thanks for the tip it was very helpful.
Best regards
Gustavo Sousa
paolo bevilacqua Sun, 02/10/2008 - 11:20
  • Hall of Fame,
    Founding Member
You're welcome, thanks for the nice rating and good luck!
