Load Balancing on 2811 with on 4 port 10/100 HWIC
Feb 9th, 2008
I am having a cisco 2811 router with one inteface (Fastethernet 0/0) connected to the lan and is also the gateway and other interface is FE 0/1 is connected to a Wireless Radio which have a bandwidth of 15 Mbps to a office near by which also have the same set up connected in the same way.
Now i need to double the bandwidth by adding on more wireless device on either ends.how can i load balance on the 4 port HWIC card on 2811 on both side.
It should be load balancing not fault tolerent.
Please help
Overall Rating: 4 (2 ratings)
Paolo Bevilacqua Sat, 02/09/2008 - 13:01
Configure additional vlans 2, 3, 4. Assign each one to a port with "switchport access vlan X". Assign a different address and subnet subnet to each VLAN. Make sure you can ping everything as supposed.
Configure a routing protocol of your choice, suggest ospf. You will have load balancing and fault tolerance.
tecnetpro Wed, 02/13/2008 - 10:48
Thanks.
Can you please help me in configuring the loadbalancing with ospf on cisco 2811 router.
Paolo Bevilacqua Wed, 02/13/2008 - 11:21
Can you get first to the step where you have the 4 vlans set and can ping each the corresponding each IP on the other side ?
Do configure your radios IP in the same subnet for each subnet, so you can manage them as well.
eg
int fa 0/2/0
switchport access vlan 10
int fa 0/2/1
switchport access vlan 11
int vlan 10
ip address 10.0.10.1
int vlan 11
ip address 10.0.11.1
etc ...
tecnetpro Wed, 02/13/2008 - 11:37
Thanks for the reply..
i have ordered for the HWIC's and will be getting in 2-3 days time. but i want prepare an outline before trying this.
i am taking my old ccnp books and reading ospf now.since i am into voice solutions for the past 3 years,i am completely out of touch with dynamic routing protocols..
Paolo Bevilacqua Wed, 02/13/2008 - 11:44
Hi, it's all automatic and no need to worry too much about. Assuming the addresses I used as example:
router ospf 1
network 10.0.0.0 0.255.255.255 area 0
redistribute connected subnets
And that's it.
tecnetpro Wed, 02/13/2008 - 11:47
Thanks for quick replay.
i will get back to you as soon as i finish configuring this.
