CSS configuration quistion
Feb 9th, 2008
can I configure the CSS11506 to do the following:
For contentA
IF response low
IF new session
redirect to sorrypage
ELSEIF existed session
keep the session open (active).
If it can be done, please advice how can I do it?
Any menment will be appreciated
Thanks in advance
Gilles Dufour Sun, 02/10/2008 - 13:09
your elseif is always true.
An active connection will stay active with the server whatever happens.
Now, what I'm not sure to understand is the "IF response low".
Could you clarify ??
Are refering to response time ?
Is this HTTP or another protocol ??
I think your goal is find a keepalive that will bring the server down when you need it.
If you can find the right keepalive, the rest of your algorithm will be fine.
