VPN Client remote Access VPN CLient
Feb 9th, 2008
I have A VPN 3000 Concentartor, and ussually user VPN Client to remote Access coorporate network. If I'm connect Vpn Client, can i connect access to another VPN Client that connect the same VPN 3000 concentrator? How to configure..?
ivillegas Thu, 02/14/2008 - 12:45
You will have to override the Tunnel Default Gateway to enble communication between clients.. This feature is called Hairpinning. Release 4.1 and later lets you define a filter rule in order to override a tunnel default gateway.
