AIP-SSM POSPF not working at all
Answered Question
Feb 9th, 2008
I want to configure the passive os detection on a ASA-SSM10, i tried to configure from IDM from CLI but still no results. The Learned OS window is empty.
CLI output:
os-identification
calc-arr-for-ip-range: 0.0.0.0-255.255.255.255 default: 0.0.0.0-255.255.255.255
configured-os-map (ordered min: 0, max: 50, current: 0 - 0 active, 0 inactive)
passive-traffic-analysis: Enabled default: Enabled
sh os-identification vs0 learned
No mappings available for the requested parameters.
The IPS version is 6.0(3)E1.
Any ideas?
Thanks!
Correct Answer by marcabal about 9 years 2 months ago
There is a known issue with Passive OS Fingerprinting on the SSMs.
CSCsi52422
The problem has been fixed and will be available in an upcoming 6.0(4) Service Pack.
Overall Rating: 5 (1 ratings)
gfullage Sun, 02/10/2008 - 21:10
  • Cisco Employee,
Your configuration is OK, I have the exact same in mine and OS learning is working fine. Are you sure your SSM is seeing traffic from the ASA, have you set up a service policy to direct traffic to it?
Do "sho service-policy" on the ASA and make sure it is actually sending data to the SSM.
oszkari Mon, 02/11/2008 - 00:50
Yes, all traffic is redirected to SSM, with a permit any class map.
The signature detection is working fine, I have problem only with the OS learning.
Correct Answer
marcabal Mon, 02/11/2008 - 08:07
  • Cisco Employee,
CSCsi52422
