OSPF E2 type route
Answered Question
I am a bit confused with the ospf type E2 route. As per the doc when a route is marked as type E2, it does not calculate the metric to the ASBR
Then referring to the attached diagram, why isn't that iam seeing 2 routes for the subnet 1.1.1.0/24 and the drfault 0.0.0.0
R2 and R4 have been configured with default-information originate command
At R3 I see only one default route from R2.
Ambi
Correct Answer by Edison Ortiz about 9 years 5 months ago
Ambi,
What you are seeing is called recursive-routing. In order for R3 to know about routes from R4, the cost is 2 from R3 (see show ip route)
O 20.20.20.4 [110/2] via 30.30.30.2
while in order for R3 to know about routes from R2, the cost is 1 - the cost of the fastethernet interface.
Increasing the cost on the fastethernet interface on R3 that is facing R2 (ip ospf cost 2) should provide the desired result.
HTH,
__
Edison.
Overall Rating: 5 (3 ratings)
Edison Ortiz Sun, 02/10/2008 - 07:22
  • Hall of Fame,
    Founding Member
Can you post the show ip ospf database from R3 ?
__
Edison.
Correct Answer
Edison Ortiz Sun, 02/10/2008 - 09:16
  • Hall of Fame,
    Founding Member
Ambi,
HTH,
__
Edison.
Edison Ortiz Sun, 02/10/2008 - 09:54
  • Hall of Fame,
    Founding Member
> result.
Looking back, I'm not 100% sure about this statement as R3 sees R2 via connected so OSPF does not play a part of the cost here. Please test and let me know.
__
Edison.
royalblues Mon, 02/11/2008 - 00:04
  • Green, 3000 points or more
Edison is absolutely correct that the behavior is due to recursive routing.
I managed to lab the setup and it works
you should see the two routes in the rotuing table as required if you increase the ospf cost to 2 between R2 and R3
Narayan
s.arunkumar Mon, 02/11/2008 - 00:43
  • Bronze, 100 points or more
Nice topic.. :)
To add to edison point
"If the external routes are both type 2 routes and the external costs to the destination network are equal, then the path with the lowest cost to the ASBR is selected as the best path.""
REF:: http://www.cisco.com/warp/public/104/1.html#t32
arun
