DHCP
TECH-JEFF
Hi to all members, I'm trying to configure a Cisco 2600 router to do DHCP tried following the steps here:
http://www.routergeek.net/content/view/37/37/
But no luck, my client pc cant get an IP address from the router. Any help will be appreciated. Thanks in advance and good day to all.
Jefferson Co
8 Replies 8
gauravshar
Level 2
Level 2
Kindly describe the topology how the clients are connected to the network. Also post the running config of the router which you want to act as DHCP server.
--gaurav
from the FastEthernet of the router a straight through cable going through a Linksys 24 port switch and the client pc's are connected from the switch using straight through cable as well.
Attached in this message as well is a copy after I typed in sh running-config
Jefferson Co
I'm not able to understand anything in the file attached. The word are inter-mingled. Kindly paste it directly on the space here.
--gaurav
Also let us know if you have created some vlans in your switch. preferably paste switches' config also.
--gaurav
we can't read that config you posted. some of it's garbled. can you repost it please.
sorry for the inconvenience, let me post it here directly...
there are no vlans configured in the switch
Current configuration : 1160 bytes Director response protoco
version 12.3y
service timestamps debug datetime msec####################ing Monitor
service timestamps log datetime msecservices
no service password-encryption Cisco Express F
!w
hostname Topect an inter
!c
boot-start-marker
Smart In
clas
boot-end-marker Follow clas
!e
enable secret xxx ID MEMORY_REQ TYP
no aaa new-model Add a co
ip subnet-zerotry2
ip cef980 C2
!0
!u
no ip domain lookupmm
default-gatewa
ip dhcp pool dhcpdhcp gateway (if not rout
network 192.168.0.0 255.255.255.0vr utility command host/portP NAT in
default-router
!C
!f
!u
!t
!U
!N
!N
!u
!a
!b
!u
!n
!a
!u
interface FastEthernet0/0t Configure p
ip address 192.168.0.254 255.255.255.0roblem andhanismPv6 configuration
Top
ip broadcast-address 192.168.0.0p-server Specify addr
duplex autoerver to use
speed autoEM up to: 4
interface Serial0/0ess-l
Using 6 per
no ip address Conf
ip broadcast-address 0.0.0.0 Restricted Rights L
shutdownformation
!s
interface FastEthernet0/1 IP DNS Resolverisclos
no ip addressrnment isab
ip broadcast-address 0.0.0.0 Domain name to complete un
shutdownhost name
duplex autoparagraphm n
speed autoounting ent
!e
interface Serial0/1ble
domain-looku
no ip addressble IP Domain
ip broadcast-address 0.0.0.0 Sets the max
shutdown
Software clause
ip classless. 252.227-70
!m
line con 0 global co
password consolep@ssstems, Inc.Engine str
login
speed 115200ist Add
line aux 0 community
line vty 0 4on System S
login Sa
!J
!e
endlif
Top#sh running-conf
finger
Building configuration...o Internetwork Operating
Current configuration : 1160 bytesConfigure flow aggregationS (tm) C
!0
version 12.32600-IK9O3S3
service timestamps debug datetime msec Configure netflow cache parameters
service timestamps log datetime msec pa
c3)cef
Technic
flow-expor
no service password-encryption to send flow statisticsatic m
!t
hostname Topclass
Copyri
!t
boot-start-markercisco System
fo
boot-end-marker Controls
!r
enable secret xxx
dns-server 208.67.222.222ARPs for PPP/SLIP peer addre
domain-name acs.com.ph Delivery of Cisco crypto
!a
ip audit po max-events 100y
host
ip dhcp-server 172.31.3.91stname tablerd-party autho
!t
!t
!i
!o
!x
!r
!s
!i
!t
!o
!u
!c
!p
!o
interface FastEthernet0/0le host-based routing (pr
ip address 192.168.0.254 255.255.255.0 distributors and users are responsible
ip broadcast-address 192.168.0.0 Enable the HP proxy pr
duplex autowith U.S. an
speed autotry laws. B
!u
interface Serial0/0 http
no ip addressver configurat
ip broadcast-address 0.0.0.0to comply with applicabl
ic
shutdown
!l
interface Serial0/1cryptographic produ
no ip addressd at:lationix-
ip broadcast-address 0.0.0.0cify local optionson configur
shutdown
http://w
interface Serial0/2ile
no ip address IP services
no ip http server
no ip http secure-server
ip classless
line con 0
password xxx
login
speed 115200
line aux 0
line vty 0 4
login
end
Top#
Jefferson Co
What you have posted is still unreadable due to the intermixture of various text outputs. I suggest that you go back to the router and do a fresh capture of the running config text and post an easier to read and understand version.
Rick
Rick
Though the pasted message is not clear, Iam just thinking there should be ip dhcp on the interface where the address needs to be assaigned by dhcp.
