RESET-I Meaning
Feb 10th, 2008
Hi, im hopeing someone will be able to clear this up for me.
When you get a RESET-I message in your syslogs, what does this mean ?
I know this is reset from the inside, however what is the inside ?
Is it the host that initiates the connection ? or the host on the higher of the security interface ?
I am confused about this ?
Any help appreciated.
gfullage Sun, 02/10/2008 - 19:45
"Inside" is the host on the higher security interface. It doesn't necessarily have to be on an interface called "inside" though. For example, if it's traffic from DMZ (sec-level 50) to outside (sec-level 0) then in this case the DMZ interface would be considered "inside".
