Error, please help!!!!
Feb 10th, 2008
whenever I do "sh run", I get nothing.
If I do "show start", I get the following
C2621#sh start
Using 10783 out of 29688 bytes, uncompressed size = 25550 bytes
%No memory availableCouldn't uncompress config (-1)
%Error opening nvram:/startup-config (Uncompression Failed)
Basically, I can not see the running
config and start-up configuration unless
I reboot the router (IOS with Firewall
Feature set). Anyone know why?
I delete the nvram:private-config but it does not help. Can anyone help?
C2621#sh ver
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(24a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 18-Dec-07 19:01 by stshen
Image text-base: 0x80008098, data-base: 0x81A1E370
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
C2621 uptime is 18 hours, 17 minutes
System restarted at 02:45:35 UTC Sun Feb 10 2008
System image file is "flash:c2600-ik9o3s3-mz.123-24a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco 2621 (MPC860) processor (revision 0x102) with 59392K/6144K bytes of memory.
Processor board ID JAD12345X7 (123456787)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
3 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
C2621#sh run
C2621#sh start
C2621#wr mem
startup-config file open failed (Not enough space)
C2621#dir flash:
Directory of flash:/
1 -rw- 16077544 Mar 1 1993 00:04:41 +00:00 c2600-ik9o3s3-mz.123-24a.bin
16252924 bytes total (175316 bytes free)
C2621#dir nvram:
Directory of nvram:/
13 -rw- 10783 <no date> startup-config
14 ---- 4275 <no date> private-config
1 -rw- 0 <no date> ifIndex-table
2 ---- 13 <no date> persistent-data
29688 bytes total (12530 bytes free)
sivakondalarao Mon, 02/11/2008 - 04:44
what about switch functionality. It is clear that show start and show run commands are not displaying configuration.
what about other commands and switch functionality.
cisco24x7 Mon, 02/11/2008 - 05:11
The router is working and passing traffics
just fine. Other commands such as "show
interface" and "reload" work. After
about 2 hours, I can not even telnet/ssh
into the router anymore and it required
a power OFF/ON.
CCIE Security
sivakondalarao Mon, 02/11/2008 - 21:19
Are you able to capture the log/console messages during problem.
Please post your tech support file.
If possible try with different IOS image even the current IOS worked fine for quiet some time.
