Warning message
No Access to Some sites
Feb 10th, 2008
Every thing is working well in my firewall, I have the DMZ working ok, I can access the net, I can create a VPN into my network.
The only problem is that I can access most os the sites in the web, but there are some that do not work like http://www.microsoft.com or http://www.sapo.pt I don't understand what is going on.
Please help me.
abinjola Tue, 02/12/2008 - 05:43
  • Cisco Employee,
is it pix or ASA ?
decrease the MSS to 1100 and then try
vmgng3077 Tue, 02/12/2008 - 15:58
I have a router 877w-n with firewall ios on it.
richardowen123 Fri, 02/15/2008 - 02:13
check the match protocol dns, I had the same problem where www.intel.com wouldn't work. Change the default value from 512 to 1024, hopefully this might solve the problem
rich
vmgng3077 Mon, 02/18/2008 - 07:35
I am not an expert. Wich instrution sould I use to change it or can I use SDM console to change it.
