ONE DID to hunt group
Feb 10th, 2008
I've got a UC520 with 4 line ISDN inward only one number on all the lines. I want a hunt group 5001 to ring when one of the BRI is called.
Can someone help me out
Overall Rating: 5 (1 ratings)
pcameron Sun, 02/10/2008 - 16:45
  • Cisco Employee,
If you want to assign one of your DID's for the hunt group, you can do the following:
Assuming you have the following DID range on the BRI services -
BRI 1 - 555101X
BRI 2 - 555102X
You use internal extensions in the range 10XX and you want the number 5551029 to ring direct to you hunt group 5001.
voice translation-rule 567
rule 1 /^5551029/ /5001/
rule 2 /^55510\(..\)/ /10\1/
(this will translate numbers in the range 5551000 - 5551028 to 1000 - 1028, and 5551029 will be translate to 5001)
voice translation-profile Hunt_Group
translate called 567
voice-port 0/0/0
description - BRI 1
compand-type a-law
cptone AU
translation-profile incoming Hunt_Group
voice-port 0/1/0
description - BRI 1
compand-type a-law
cptone AU
hotrot_net Mon, 02/11/2008 - 01:03
The problem is that I only have 1 DID namely
493440075 thats the only DID i have got I want that to ring on hunt group 5001
Greetings Andy
pcameron Mon, 02/11/2008 - 03:25
  • Cisco Employee,
Providing the telco sends all the digits in the setup message, make the translation rule like this -
rule 1 /^493440075/ /5001/
Otherwise run debug ISDN q931 and look at whatever the called number is in the setup message. Change the number in the voice translation rule to suit.
