Remote access on VPN depends on location
Feb 10th, 2008
I have the ASA 5505 set up for a remote VPN. I am able to connect to the router from remote locations. However, I am not able to get to the LAN side of the router from each remote location. Some of them I can. Remote locations are hotel rooms, other offices, etc. Any ideas?
Kevin Hill
srue Mon, 02/11/2008 - 06:20
  • Blue, 1500 points or more
Can you post your config? Also, by 'router',do you mean the ASA5505 firewall?
hill.kevin Mon, 02/11/2008 - 09:48
Yes, but you will have to give me some help on how to do that. By router, I meant the PIX I guess. Thanks!
d-rivers Mon, 02/11/2008 - 14:57
Sounds like you need to enable Nat-Traversal on the 5505.
Dave Rivers
