how to configure leased line on 1841
Feb 10th, 2008
please can anybody help me out with the commands to configure leased line on 1841
Overall Rating: 2 (1 ratings)
Goutam Sanyal Mon, 02/11/2008 - 04:24
Pls find the simple configuration of a leased line:
1.interface Serial0/0/0
2.description *** LEASED LINE ***
3.bandwidth 256
4.ip address x.x.x.x
5.encapsulation ppp
6.max-reserved-bandwidth 100 shut
1. login to the particular interface (May be Serial/FastEthernet)
2. Set the description (Optional)
3. set the bandwidth
4. set the IP Address for you network.
5 Set the encapsulation method.
6. set the command to utilized the full bandwidth of the link. (Optional)
7. no shut. (Vital) to bring the interface up.
It's the simple configuration.
Pls rate if it works
Goutam Sanyal Wed, 02/13/2008 - 04:32
Hi Chris,
You are right, but please tel me one thing, if my service provider is giving me xy KBPS, then why it will not used? Its true that this parameter is use for routing protocol.
Pls inform
