FXO port config issues
Feb 10th, 2008
Dear Pros,
can you check this? I can see the FXO card through the sh ver but I cannot get to the port to configure it. This is mostly an IOS issue, but I want to make sure of it because the IOS is 4.0 enterprise, which I though support voice and this router is so critical which I don't want to take the chance to miss with it.
Sh Ver
Cisco 2821 (revision 53.51) with 1036288K/12288K bytes of memory.
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
R100-International(config)#dial-peer voice 7 pots
R100-International(config-dial-peer)#des
R100-International(config-dial-peer)#dest
R100-International(config-dial-peer)#destination-p
R100-International(config-dial-peer)#destination-pattern 3....
R100-International(config-dial-peer)#dir
R100-International(config-dial-peer)#direct-inward-dial
R100-International(config-dial-peer)#port ?
% Unrecognized command
swami
paolo bevilacqua Mon, 02/11/2008 - 02:20
  • Hall of Fame,
    Founding Member
Hi, most likely you do not have the necessary DSP modules in the router, do "show diag" to know. You should see PVDM2-xx without it you canno have the voice port to work.
arumugasamy Thu, 02/14/2008 - 04:27
Dear,
My customer looking for the supporting documents.Where can we find it?
Swami
