FWSM - multiple interface and NAT
Answered Question
Hello:
I am in the process of configuring FWSM and want to have 3 inside interfaces and one outside. The Securty level for these interfaces as follows:
Outside - 0
Inside_1 - 80
Inside_2 - 70
Inside_3 - 60
But I don't want to perform NAT on any of them. Is this posiible (or do I have to setup same security levels for these interfaces to perform no NAT)?
Thanks in advance.........
Correct Answer by cisco24x7 about 9 years 3 months ago
With FWSM version 3.x or higher, the blade,
by default, will route traffics so you do
NOT have to do anything. You still need
ACL to go from low to high but NOT from high
to low.
If you still use fwsm version 2.x, you still
NEED to perform no NAT to go from high to
low
CCIE security
Overall Rating: 5 (2 ratings)
Correct Answer
cisco24x7 Mon, 02/11/2008 - 05:13
  • Silver, 250 points or more
to low.
low
CCIE security
