Etherchannel suspend
Feb 11th, 2008
I have 2 interface bundled in channel if one of interface change state to suspend (speed and duplex mismatch) but the remain interface still up and in channel why all traffic can't pass on remain interface in channel ( ex.I can't ping neighbor switch )
aijaz802 Mon, 02/11/2008 - 02:22
Pls. check whether the port channel is up on both ends. check the trunk and allowed vlans(if any) configuration.
Are u able to ping with only one interface in ether channel either side?
If one of the interface is down then also the port channel should work, thats why port channel also used for the redundancy. Please re-check the channel configuration.
Rate if it helps.
