Avaya Phone connected to Cisco 3560
Feb 11th, 2008
hi Guys,
i need help on configuration of a port which is connected to avaya phone. the data vlan is 10 and voice vlan is 20.
how the configuration will look like..
is the port needs to be configured as trunk ?
regards
amit
jbroderick Tue, 02/19/2008 - 13:42
Here is what I have done. You can use this for Avaya and Cisco phones. Most of this is auto qos voip trust configuration:
interface GigabitEthernet0/2
description Jack#1406 pp1-2 VP User
switchport access vlan 10
switchport mode access
switchport voice vlan 20
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust cos
auto qos voip trust
spanning-tree portfast
Be aware that there aren't any Avaya phones capable of 1000baseTx.
totneteng Mon, 06/21/2010 - 11:08
I have Cisco 3560 swithces and I am also looking to enable QOS for VOIP. Using Avaya.
Below is what I found. I would appreciate if someone can confirm.
ip cef distributed, and enable "auto qos voip trust" under the interface where the phones are connectd.
Nav
