IP addresses may not be configured on L2 links.
Feb 11th, 2008
Hello to all, 877 have just brought a shindy but I have problems to form the fastethernet, on having tried to form an ip address it(he,she) appears:
Since I can solve it? I have tried to use the SDM but it(he,she) does not assign me ip for DHCP. Thank you very much
Overall Rating: 4 (2 ratings)
andrew.burns Mon, 02/11/2008 - 03:04
  • Gold, 750 points or more
Only the Ethernet WAN interface can have an IP directly assigned. The LAN interfaces need to be assigned to a VLAN, which has the IP address.
Have a look at the following and post again if you still have trouble.
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/dhcpvlan.html#wp999406
and this link has a complete sample config:
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/sampconf.html
Andrew.
nachogdiaz Mon, 02/11/2008 - 03:11
Hello Andrew, I continue with the same mistake, not because it(he,she) does not warn me: (
cadrn@tdc.dk Tue, 02/12/2008 - 04:16
use the interface vlan 1 command:
interface vlan 1
ip address x.x.x.x y.y.y.y
no shut
that shut do it!
