Unity 5.0(1) + Phone View
I have found an issue with Unity 5.0(1) and Phone View, If I set the Conversation Language set to (English United Kingdom). However when I call in and select option 5 and then 4 to display messages on the phone I get an error of - "Searching .... The system cannot display messages on your phone, contact your system administrator"
If I change the Conversation Language to English (United States) all works fine.
Is there any way of getting the Phone View option working with the UK conversation?
Glen
mrmccann Tue, 02/12/2008 - 11:25
  • Cisco Employee,
Are you using the same phone for both test calls? I am not aware of any Phone View issues that impact UK English.
g-kennett Tue, 10/21/2008 - 07:09
Did anyone get to the bottom of this. I am having exactly the same issue.
Glyn
Rob Huffman Tue, 10/21/2008 - 08:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Glyn,
It looks like this bug;
CSCso17525 Bug Details
Unity 5.0(1) - Message Locator does not work with UK English.
Symptom:
After changing the TUI language to ENG visual message locator will fail to display messages.
Following message will be prompted:
The system can not display messages on your phone. Contact your system administrator.
Repro:
1. Dial in to Unity
2. To find a message press 5
3. To display all new messages press 4
4. Searching
5. The system can not display messages on your phone. Contact your system administrator.
Event Viewer will show following error:
Event Type: Error
Event Source: CiscoUnity_PhraseServer
Event Category: None
Event ID: 10002
Date: 3/12/2008
Time: 2:53:45 PM
User: N/A
Computer: UNITY5UM
Description:
(MyJsExt.cpp) Script: subsearchmsgstack_ENG.ps (JavaScript) -- $FILE:C:\CommServer\Localize\Scripts\ENG\subsearchmsgstack_ENG.ps $LINE:203 -- ReferenceError: PHNAP_CISCOIPPHONEMENG is not defined
Conditions:
The TUI language is set to UK English (ENG).
This defect exists in Unity 5.0(1). It does not exist in Unity 7.x and later.
Workaround:
Use a text editor (e.g. notepad.exe) to modify lines 203 and 206 of
\Commserver\Localization\Scripts\ENG\SubSearchMsgStack_ENG.ps as follows:
original line 203 phone.xml_object = PHNAP_CISCOIPPHONEMENG;
original line 206 lMaxMenuItems = MAX_ICONMENG_ITEMS;
fixed line 203 phone.xml_object = PHNAP_CISCOIPPHONEMENU;
fixed line 206 lMaxMenuItems = MAX_ICONMENU_ITEMS;
Hope this helps!
Rob
g-kennett Wed, 10/22/2008 - 13:19
Hey Rob, many thanks for this. I have made the changes and will be able to test Friday. I'll let you know the result.
Thanks again
Glyn
g-kennett Fri, 10/24/2008 - 04:39
Many Thanks for your post Rob. This has done the trick.
Kind Regards
Glyn
Rob Huffman Fri, 10/24/2008 - 04:56
  • Hall of Fame,
    Founding Member
Hey Glyn,
You are most welcome! Thanks for posting back with your results. This type of follow-up really helps others going forward :)
Cheers!
Rob
