CTI OS Login
Feb 11th, 2008
Contact Center Agent using ip phone 7971G cannot login to CTI OS 7.0.0 Agent Desktop .The system returns the error message below in an attempt to login:
IPCC Error (12005)
Login could not be performed- Possible causes are:
1. invalid instrument
2. media termination problem
3. or other CM issues
The Agent can login to the application using another instrument like 7961G. Anyone knows what could possibly be the problem here?
Overall Rating: 5 (1 ratings)
Patrik Englund Mon, 02/11/2008 - 04:28
Is the instrument associated with the correct user in callmanager?
Is the instrument added as device target in ICM?
Is there a firewall between pg's and call manager? Try recycle the pg's if so. We have firewall between and i have to cycle the pg's for the most to get them registered.
sundayokpala Tue, 02/12/2008 - 09:00
Hi Patrik
Thanks for your prompt response. i have actually taken the steps you advised but the problem has yet to be resolved.
Do you think there is anything i need to do further to fix this issue?
Sunny
david.macias Tue, 02/12/2008 - 10:32
Check the CCM and ensure that all partitions, CSS, are set correctly for that device.
david
Patrik Englund Tue, 02/12/2008 - 22:30
I have had this issue sometime when the agent suddenly cannot log on to the selected device although that it worked the day before. The solution was then to do a hard resett (pull the powercord) on the hard phone so it did a total reboot and reregistered to call manager. Then it worked again to log on to the device. Try this
Brandon Miller Tue, 02/12/2008 - 11:27
Try disassociating and reassociating the correct device from the jtapiuser.
Ensure that the Device Target is configured in ICM.
sundayokpala Wed, 02/13/2008 - 01:04
Hi Guys
i wana thank you all for your responses,they were really very helpful.The login problem has been sorted.i had to associate the device with icm in the Application User page of User Management in the CCM as suggested by Branmill in his response.
You guys are too much.
Abdulbaseer Mohammed Thu, 02/14/2008 - 06:49
this usually solves problems like this. Some thing can't be explained very well but it works.
hope the person seeking help rate helpful posts.
thanks,
Baseer.
