Dial peer voice question
Feb 11th, 2008
Is it possible to route a call based on it's ANI(calling number)? I know I can manipulate the digits, but that's not what I am looking for. As an example, I get a call from 555, I want it routed to specific extension or voice port regardless of the called number. Thanks.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 02/11/2008 - 05:31
  • Hall of Fame,
    Founding Member
Hi, this done quite easily when you've h.323 or sip to connect the GW, using-answer-address and translation-profile under the incoming DP, but if you're using MGCP I hope someone else can suggest something as I' unable to help with that.
