change WCS smtp notification
Feb 11th, 2008
does anyone knows how to change the SMTP server and/or address for email alert notification ?
I tryied to change the email address in the Admnistrator menu, but the alarm are not upgraded. They retain the old email.
Is there any way to remove the SMTP server configured ?
regards
Luigi
LUIGI PIETRONAVE Fri, 02/15/2008 - 16:03
thanks for the reply, but i was searching ( i suppose it's just a "cosmetic bug" ) a way to:
- remove mail server: it seems when You configured, You can just change it, not remove.
- change the sender address from the server configuration ( and this i was imaging it had to change all the events sender address ).
I try to explain better last phrase.
When You set the mail server FOR THE FIRST TIME, all events are configured automatically with the sender address you configured ( for example [email protected] ).
If You change [email protected] to, for example, [email protected], gets changed just the events not enabled.
To change all the events You have to edit them everyone .
Luigi
Trending Topics - Security & Network
