DBLHELPER file for CCM 4.1(3)
Feb 11th, 2008
Hi dear cisco forum, I have CCM 4.1(3)sr5d servers installed (Publisher and Subscriber) but the DBLHELPER files to reestablish a broken SQL subscription is missed in this version. It is neccesary to open a TAC case in order to obtain this file?. Or, it could work too if someone in the forum would send or add this file to make it work.
Thank a lot friends
David
Overall Rating: 5 (1 ratings)
Ayodeji Okanlawon Mon, 02/11/2008 - 05:58
Ensure that you are running the dblHelper from this folder:
c://programfiles/cisco/bin...
If you are not, copy it to this folder and run it again..
david-lima Mon, 02/11/2008 - 06:06
Thanks for your reply. I search this file but in my CCM Publisher, but I can't find it.
Is it necessary to open a TAC case to obtain this file?.
Thanks a lot boys
David
david-lima Mon, 02/11/2008 - 06:20
Thank you very much for your help and the file my friend, just one nmore question, Is this file compatible with my CCM 4.1(3)?.
David
david-lima Mon, 02/11/2008 - 06:31
Thank a lot my friend, I'm going to reestablish the broken connection in a few minutes.
Thanks, thanks.
David
