dhimancisco Mon, 02/11/2008 - 23:28
u can try like this
int vlan x
ip add x.x.x.x x.x.x.x
no shut
int vlan x
no shut
ip routing
router ( routing protocol which u are using)
network x.x.x.x (this portion is totally dependent on the protocol u r using)
ip default-gateway x.x.x.x ( if the switch is connected to the router/switch , then the interface through which it is connected,the ip add of the interface will be the ip of the default-gateway)
now if u are coing to configure ur vlans in database( in case u are creating subinterfaces in router and creating vlans for those subnetworks).
then follow this
#conf t
#vlan X
(vlan)#name XXX
exit
#conf t
#vlan X
(vlan)#name XXX
exit
vtp domain XXX
vtp mode server/client (as per u)
if u cn tell me in detail...I can help u better.
If it works then rate it pls
Goutam Sanyal Tue, 02/12/2008 - 00:10
  • Silver, 250 points or more
According to Cisco:
Cat3550#show running-config
Building configuration...
Current configuration : 3092 bytes
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Cat3550
ip subnet-zero
!--- Enable IP routing for interVLAN routing.
ip routing
interface FastEthernet0/1
no ip address
!--- Output suppressed.
interface FastEthernet0/5
description to SERVER_1
!--- Configure the server port to be in the server VLAN, VLAN 3.
switchport access vlan 3
!--- Configure the port to be an access port to prevent trunk negotiation delays.
switchport mode access
no ip address
!--- Configure PortFast for initial Spanning Tree Protocol (STP) delay. Refer to
!--- Using PortFast and Other Commands to Fix Workstation Startup Connectivity Delays
!--- for more information.
spanning-tree portfast
interface FastEthernet0/48
description To Internet_Router
!--- The port that connects to the router converts into a routed (L3) port.
no switchport
!--- Configure the IP address on this port.
ip address 200.1.1.1 255.255.255.252
interface GigabitEthernet0/1
description To 2950
!--- Configure IEEE 802.1 (dot1q) trunking, with negotiation, on the L2 switch.
!--- If there is not support for Dynamic Trunking Protocol (DTP) on the far switch,
!--- issue the switchport mode trunk command to force the switch port to trunk mode.
!--- Note: The default trunking mode is dynamic auto. If you establish a trunk link
!--- with the default trunking mode, the trunk does not appear
!--- in the configuration, even though a trunk has been established on
!--- the interface. Use the show interfaces trunk command to verify the
!--- establishment of the trunk.
no ip address
interface GigabitEthernet0/2
description To 2948G
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan2
description USER_VLAN
!--- This IP address is the default gateway for users.
ip address 10.1.2.1 255.255.255.0
interface Vlan3
description SERVER_VLAN
!--- This IP address is the default gateway for servers.
ip address 10.1.3.1 255.255.255.0
interface Vlan10
description MANAGEMENT_VLAN
!--- This IP address is the default gateway for other L2 switches.
ip address 10.1.10.1 255.255.255.0
ip classless
!--- This route statement allows the 3550 to send Internet traffic to
!--- the default router which, in this case, is the 7200VXR (Fe 0/0 interface).
ip route 0.0.0.0 0.0.0.0 200.1.1.2
ip http server
line con 0
line vty 5 15
end
Note: Since the 3550 has configuration as a VLAN Trunk Protocol (VTP) server, the switch does not display the VTP configuration. This behavior is standard. This switch uses these commands to create a VTP server with the three VLANs that the user defined from global configuration mode:
Cat3550(config)#vtp domain cisco
Cat3550(config)#vtp mode server
Cat3550(config)#vlan 2
Cat3550(config-vlan)#name USER_VLAN
Cat3550(config-vlan)#exit
Cat3550(config)#vlan 3
Cat3550(config-vlan)#name SERVER_VLAN
Cat3550(config)#vlan 10
Cat3550(config-vlan)#name MANAGEMENT
Goutam
[Pls rate if it works]
Source:www.cisco.com
Johann Frey Wed, 02/13/2008 - 03:38
how can you deny traffic between MANAGEMENT_VLAN (Vlan10) and the other Vlans?
Goutam Sanyal Wed, 02/13/2008 - 04:49
If u r not using inter-vlan routing, then no vlan will communicate to each other.
Also u can define via Vlan-ACL
Goutam
