Tuning SIG 5583 - SMB Remote SAM Service Access Attempt
Feb 11th, 2008
We are running Active Directory and this sig is firing 30000+ times a day. I do not want to disable the sig as we would likt to watch for external IP's as the source or destination.
Trouble is I cannot get an event filter to work for this beast and I cannot filter it at the sig level since there is no source/destination IP settings in the sig itself (SMB Engine).
Here is the event filter definition:-
signature-id-range: 5583,5579 default: 900-65535
subsignature-id-range: 0-255 default: 0-255
attacker-address-range: $Inside default: 0.0.0.0-255.255.255.255
victim-address-range: $Inside default: 0.0.0.0-255.255.255.255
attacker-port-range: 0-65535 <defaulted>
victim-port-range: 139,445 default: 0-65535
risk-rating-range: 1-100 default: 0-100
actions-to-remove: produce-alert|produce-verbose-alert default:
deny-attacker-percentage: 100 <defaulted>
filter-item-status: Enabled default: Enabled
stop-on-match: True default: False
user-comment: <defaulted>
os-relevance: not-relevant default: relevant|not-relevant|unknown
The $Inside variable is 10.0.0.0-10.255.255.255
basically our entire internal network.
The events I am being flooded with are single events and not summarized.
Here is an example of an alert:-
evIdsAlert: eventId=1192231627181681635 vendor=Cisco severity=informational
originator:
hostId: IDS
appName: sensorApp
appInstanceId: 571
time: 11 February 2008 15:59:52 UTC offset=0 timeZone=GMT00:00
signature: description=SMB Remote SAM Service Access Attempt id=5583 version=S262
subsigId: 0
sigDetails: SMB Remote SAM Service Access Attempt
marsCategory: Info/Misc/NetBios
interfaceGroup: int8
vlan: 36
participants:
attacker:
addr: 10.36.3.52 locality=Inside
port: 2956
target:
addr: 10.11.1.63 locality=Inside
port: 445
os: idSource=learned type=windows-nt-2k-xp relevance=relevant
riskRatingValue: 25 targetValueRating=medium
attackRelevanceRating=relevant
threatRatingValue: 25
interface: ge0_8
protocol: tcp
As you can see BOTH the source and destination are within the ranges specified in the filter but the event is still firing.
mhellman Mon, 02/11/2008 - 15:17
hmm..nothing stands out as being wonky in my mind. The only thing I can think of is to check for another filter that matches before with a 'stop on match' that doesn't remove the alert action(s).
andrewtorry Tue, 02/12/2008 - 00:50
Forgot to mention that I have moved this filter to the TOP to specifically avoid any previous filters getting in the way.
mhellman Tue, 02/12/2008 - 05:41
You might try entering a static IP range in the filter and see if it works.
andrewtorry Tue, 02/12/2008 - 05:48
You mean replace the $Inside with a specific range like 10.0.0.0-10.255.255.255.
Hmm. Nope. I have tried that and I have even tried specific IP addresses for the source/destination but still get alerts with exactly those two addresses getting through.
Filtering is working though as I have a filter active also for the 'DHCP offer' sig in that I have filtered out all our 'expected' DHCP sources, and SMTP filters for 'expected' SMTP sources.
Why can I not filter out SMB sources/ destinations such as Windows Servers and/or M$ Domain Controllers.
Come on Cisco, event filtering was so easy in IDS4, why complicate it so much in IPS6.
jakasper Tue, 02/12/2008 - 14:10
The filter says: os-relevance: not-relevant
But the alert says: os: idSource=learned type=windows-nt-2k-xp relevance=relevant
I suspect that is why this one filter is not matching.
You probally want to revert the os-relevance to its default setting for this filter.
Also, make sure you examine the 'stop-on-match' filters closely. If you match a filter that has 'stop-on-match true', it will stop evaluation of any more filters for that alert, so that could cause strange results.
-JK
