Config Editor Question
Answered Question
Feb 11th, 2008
I ran into a slight issue in Device Center.....I went into Edit Config under Management Task to enter a Tacas Statement....but whenever I try to save it comes up with Branch Name. I have used this feature several times in the past and was wondering why is this a required field.
Correct Answer by Joe Clarke about 9 years 1 month ago
You need to specify a branch name when saving the config so you have a tag that identifies this local copy of the config in case future editing is required.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 02/11/2008 - 09:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
dionjiles Mon, 02/11/2008 - 09:23
Got it.....Thanks for the quick reply. I was confused as to what to type in that field, so I used netconfig to deploy the job I wanted instead.
