host names for CUCM 5 or 6
Feb 11th, 2008
  • Green, 3000 points or more
Anyone know or remember when installing CUCM 5 or 6 if it accepts capital letters or small case or a combination when entering in the hostname?
Thanks!
Jaime Valencia Mon, 02/11/2008 - 11:30
  • Cisco Employee,
  • Hall of Fame,
    2011
as far as i remember all you suggest is supported, only the use of underscore is not supported
