Brakes ssh
Feb 11th, 2008
Is available 6509, in it 2 servers linux are connected, on a picture it is shown. I come on them on ssh, session brakes terribly, deduces pieces somehow all. I switch them in 3750, ssh flies.
For reason finding-out has altered a network - has created vlan, has placed in it 2 ports, has created the interface. 65 for servers is a sluice. As a result from a server on a server ssh works strongly slowly. ssh has moved on 55 port, there was the same. The telnet as slowly works.
Thus on ftp from them it is given on 700-900 Mbit/s. Ping between servers go remarkably.
Options of ports:
interface GigabitEthernet1/11
description FTP
switchport
switchport access vlan 5
switchport mode access
ip arp inspection trust
no ip address
speed 1000
duplex full
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
spanning-tree guard root
ip dhcp snooping trust
end
The interface:
interface Vlan5
description FTP-NET
ip address 192.168.1.230 255.255.255.248
end
Port status
#sh int gi1/11
GigabitEthernet1/11 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0015.6336.ec1a (bia 0015.6336.ec1a)
Description: FTP
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 10/255, rxload 234/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output never, output hang never
Input queue: 0/2000/105/0 (size/max/drops/flushes); Total output drops: 52
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 917844000 bits/sec, 80485 packets/sec
5 minute output rate 40813000 bits/sec, 43061 packets/sec
5271517095 packets input, 7596041637146 bytes, 0 no buffer
Received 262 broadcasts (0 multicasts)
3 runts, 0 giants, 0 throttles
18 input errors, 0 CRC, 0 frame, 87 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
2781972193 packets output, 259447685871 bytes, 0 underruns
26 output errors, 0 collisions, 5 interface resets
0 lost carrier, 0 no carrier, 183302 PAUSE output
Has switched on in another as the adjusted port a server on FreeBSD, loading on the interface
5 minute input rate 72000 bits/sec, 5 packets/sec
5 minute output rate 9000 bits/sec, 10 packets/sec
But also in this case as slowly ssh moves. Loops are not present.
ps it is exact at the same loading, and even it is more, in 3750 it did not influence in any way session ssh.
Help to find the reason slow ssh.
Reason may be VLAN Access Control Lists (VACLs) on the switch that will allow only legitimate hosts to connect to the desired services. This must be combined with Unicast Reverse Path Forwarding (uRPF), or some other anti-spoofing technique on the network edge to protect against spoofed packets from the outside of the network.
Better you reboot the device.
slava_ram Sun, 02/17/2008 - 07:48
VACL it is not used. uRPF also it is not included. reeboot has not helped.
