3750-E TenGig Etherchannel - It's possible ?!
Answered Question
Feb 11th, 2008
Hello! How are everybody?!
Question... I didn't found anything related to that... Can I create an Etherchannel using TenGig interfaces at 3750-E ?!
Each side will have 4 switches (stacked) and will be connected via TenGig interfaces, but I want to use one TenGig at the first switch and other TenGig at the last switch (T1/0/1 and T4/0/1), can I also create an etherchannel using those 10Gb ports?!
See the topology attached for a better understanding!
Thanks for your help!
Cheers,
Caue
Correct Answer by wochanda about 9 years 1 month ago
Yes you can. We support both LACP for cross-switch etherchannels and static mode on.
Overall Rating: 5 (2 ratings)
Correct Answer
wochanda Mon, 02/11/2008 - 16:57
  • Silver, 250 points or more
