Do I need to remove static routes
Feb 11th, 2008
Currently between sites A and B we have
2 t1's configured toward each other via static routes
RouterA
A#sh ip int br
Interface IP-Address
FastEthernet0/0 192.168.21.236
(lan)
Serial0/0 192.168.100.253
(t1 link)
FastEthernet0/1 192.168.255.129
(wireless link)
Serial0/1 192.168.100.249
(t1 link)
ip route 192.168.2.0 255.255.255.0 192.168.100.254
ip route 192.168.2.0 255.255.255.0 192.168.100.250
router ospf 100
router-id 192.168.21.236
log-adjacency-changes
redistribute connected subnets
network 192.168.1.0 0.0.0.255 area 1
network 192.168.100.0 0.0.0.255 area 1
network 192.168.118.0 0.0.0.255 area 1
network 192.168.255.0 0.0.0.255 area 1
Router B
b#sh ip int br
FastEthernet1/1 192.168.255.130
(wireless link)
Serial1/0/0:0 192.168.100.254
(t1 link)
Serial1/0/1:0 192.168.100.250
(t1 link)
ip route 192.168.1.0 255.255.255.0 192.168.100.249
ip route 192.168.1.0 255.255.255.0 192.168.100.253
router ospf 100
redistribute bgp 62001 subnets
network 192.168.2.0 0.0.0.255 area 1
My question is...we are adding a third link btwn the two..routers..that is the 192.168.255.129 and .130 address you see.
We would like to use this third wireless link as the primary route btwn the two sites..and if this should fail...traffic should go back to the 2 t1's we currently have configured
My question is..You can see that we have
the t1's both in ospf and static configurations...will the static configs need to be removed so ospf can take over traffic priority?
We would configure the 2 t1's t that will now be used as failover..with a higher cost
Richard Burts Mon, 02/11/2008 - 11:05
leonardo
If you reconfigure the static routes so that they have an administrative distance that is greater than the AD of OSPF then you could let OSPF select the primary route as the wireless. But if OSPF is running over the serial links then I do not see what value there is in having floating static routes since OSPF would be aware of the primary path over the wireless and the backup path over the T1s. What function would the static routes have for this?
One aspect of this question does puzzle me. The static routes are for 192.168.1.0 and 192.168.2.0 and I see that there are network statements under OSPF for these networks. But they do not show up in the show ip interface brief output. Where are these networks?
Rick
brooklynheight Mon, 02/11/2008 - 11:34
Hi Rick-
this is configured on router A
##sh run interface fastEthernet 0/0
interface FastEthernet0/0
ip address 192.168.1.236 255.255.255.0 secondary
ip address 192.168.21.236 255.255.255.0
no ip route-cache
speed 100
and this is on B
sh run
interface GigabitEthernet0/1
description Local LAN
ip address 192.168.2.236 255.255.255.0 secondary
ip address 192.168.2.245 255.255.255.0
from your viewpoint..is ospf not doing anything right now..since it looks like
routes are being chosen becuase of the static configuration?
Router A#sh ip route 192.168.2.0
Routing entry for 192.168.2.0/24
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
192.168.100.254
Route metric is 0, traffic share count is 1
* 192.168.100.250
Router B #sh ip route 192.168.1.0
Routing entry for 192.168.1.0/24
192.168.100.253
* 192.168.100.249
Richard Burts Mon, 02/11/2008 - 12:23
leonardo
Clearly in the current configuration the path chosen is via the static routes. The default administrative distance of static routes is much better than the administrative distance of OSPF and so static routes will be preferred to OSPF routes.
If OSPF will be running over both T1 links and over the wireless link and if OSPF is advertising the LAN (192.168.1.0 or 192.168.2.0) over these links then I see no reason to have static routes or floating static routes.
However based on the partial configs posted I believe that there are some issues that need to be resolved. On router A there is clearly a primary subnet (192.168.21.0/24 and a secondary subnet 192.168.1.0/24). There is an OSPF network statement for the secondary network but not for the primary network. This is generally a problem. I would suggest adding a network statement for the primary network under router OSPF. On router B the primary network and the secondary network appear to be the same 192.168.2.0/24. Is this correct? If so why is there a secondary configured?
Rick
brooklynheight Mon, 02/11/2008 - 13:24
Hi Rick-
Correct..both the primary and secondary interfaces are in the same subnet on router B
192.168.2.0-and im not sure why there is a secondary
All users are on the 192.168.2.0 network at that site
Im not quite sure why router A has 2 different
.21 as the primary...
I did notice once when we were working this
that the wireless took over via ospf and
the preferred router to router B was the wireless link
however..when logged into router B..the preferred route to router A was still the
static routes over the t1's..so it
looked like we had 1 route one way..and another route back
is this becuase ospf is not advertising
the .1 network in router A as you pointed out?
Richard Burts Mon, 02/11/2008 - 13:40
leonardo
Without some more knowledge of the environment it is difficult to say for certain. But I believe it quite likely that OSPF was not advertising the .1 network and that lead to the asymetric route.
Rick
