Connection drops between 4500 and 6500 switch
Feb 11th, 2008
Hello, I hope someone can help with this. we have 2 buidings that were recently connected by lasers. The lasers are connected to thier respective switches in each bulding. Building 1's laser is connected to a 6509 switch running catos software Version NmpSW: 6.4(21) Through gbics. Building 2's Laser is connected to a 4505 switch running software IOS Version 12.2(25) gbics. Since these buildings were connected we have been experiencing intermittent drops in connection 2-3 times an hour. Both switch ports are enabled Full-duplex. During a show tech these errors are reported:
CrcAlign-Err 294
Symbol-Err 7275310
Undersize 4054
Jabbers 18
Sequence-Err 6008107
The 6509 switch shows FCS-Err 81
I have been told that this is a fiber problem. Could it also be that the 6509 catos needs to be updated?
Edison Ortiz Mon, 02/11/2008 - 11:10
You can upgrade the OS version on the 6509 and see if it fixes the problem or better yet, during a maintenance window get another switch (if you have any spare) and replace the 6509 end for an hour.
However, I do believe it's a fiber problem.
__
Edison.
fortis123 Tue, 02/12/2008 - 13:08
I had the same kind of issue before with the similar errors.. Its physical issue. Replace to GBIC (as long as inhouse fiber is good).
It will fix it.
hth
MS
