paolo bevilacqua Mon, 02/11/2008 - 11:01
  • Hall of Fame,
    Founding Member
Not at all.
kapil.atrish Fri, 02/22/2008 - 01:43
HI,
I was checking the similar requirements. I think there could be voice quality issue due to physical disparities on T1 circuits. If there are errors/delay on one link, there will be packet losses/jitter causing bad quality to all voip connections.
Kapil Atrish
jerry.mcrae Fri, 02/22/2008 - 09:18
i added the multilink last night and ive noticed a strange issue with QOS. i cant add my service policy to one on the interfaces in the multilink.
SSF_CORP#conf t
SSF_CORP(config)#interface Serial0/1/0:0
SSF_CORP(config-if)#service-policy output EWT_SP
SSF_CORP(config-if)#end
SSF_CORP#sh run int Serial0/1/0:0
description 2ND T-1
bandwidth 1536
ip unnumbered FastEthernet0/0.10
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
ip tcp header-compression iphc-format
ppp multilink
ppp multilink group 90
max-reserved-bandwidth 100
ip rtp header-compression iphc-format
ip rtp compression-connections 64
i also get this when i do a sh policy-map interface Serial0/0/0
Queueing [suspended, using FIFO]
what gives?
paolo bevilacqua Fri, 02/22/2008 - 09:46
  • Hall of Fame,
    Founding Member
Hi, configure everything you need under multilink i nterface.
jerry.mcrae Fri, 02/22/2008 - 09:56
i have but check this out. one side of the multi i get this during sh policy-map (router 2)-
Class-map: voice-traffic (match-any)
323169 packets, 42269160 bytes
5 minute offered rate 25000 bps, drop rate 0 bps
Match: ip dscp ef (46)
269929 packets, 38969247 bytes
5 minute rate 22000 bps
Match: ip rtp 16384 16383
53240 packets, 3299913 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 39 (%)
Bandwidth 1198 (kbps) Burst 29950 (Bytes)
(pkts matched/bytes matched) 26101/3192422
(total drops/bytes drops) 0/0
on the other side i get this (Router1)-
406971 packets, 52744324 bytes
5 minute offered rate 54000 bps, drop rate 0 bps
5 minute rate 54000 bps
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Bandwidth 39 (%)
(pkts matched/bytes matched) 0/0
router 2 -> (pkts matched/bytes matched) 26101/3192422
router 1 -> (pkts matched/bytes matched) 0/0
same config on both sides. im reading a white paper on this now. ideas?
thanks - jerry
