WCS WLAN Override Mismatch
Feb 11th, 2008
Our wireless network has gone through several changes over the past year. We now only have 3 wlans. I usually created AP templates and enable WLAN override to select which APs get which wlans. WCS does not however seem to be updating with the WLCs. My only options are 3 wlans which no longer exist. I've tried restarting the service and rebooting the server. I've also tried building new templates but no luck. Anyway to get WCS to rebuild this list from the wlcs?
I'm using v 4.1.91.0,
Caveat for 4.0.100.0
CSCse42296-If a template for a given WLAN profile exists in WCS and WLAN is modified out of the band of the controller, the template is not updated to reflect the new settings.
Workaround: Make any desired changes to the WLAN settings in WCS and then apply them to the controllers.
Seems to be my problem though. I am unaware of how to change wlan settings through WCS however.
mlrtime99 Mon, 02/11/2008 - 11:52
Solved, I actually had to go into my WLC's, delete all WLANs, then go back into WCS and rebuild them under the controller template section.
Trending Topics - Security & Network
