3rd party paging integration
Not applicable
I am trying to integrate a Symetrix 421 paging to Cisco 2811 router.
Should I use a FXO or FXS port and also doyou have some configuration expamples.
15 Replies 15
paolo bevilacqua
Hi, I've located the device manual at:
http://support.symetrixaudio.com/cgi-bin/symetrix.cfg/php/enduser/fattach_get.php?p_sid=bQUnF3Yi&p_accessibility=0&p_redirect=&p_tbl=9&p_id=415&p_created=1138641843&p_olh=0
but it doesn't mention telephone interfacing, I guess a good choice could be E&M interface, however better look at the way the previous system was connecgted, or give the manufacturer a call.
Thanks P. I have already got the usermanual and I agree there is not much in their. The system is currently connected to a Nortel PBX now.
jason-calbert_2
Level 3
Level 3
Greg,
On most systems you use an FXO to communicate with a paging system. Is your 2811 MGCP or H323? This would determine the configuration examples that you would use.
It is much easier to use MGCP. You would just create a route pattern and point this to the FXO port on the 2811.
Hey Jason thanks for the quick response. We are using MGCP
Also I had found the user manual to the Symetrix device before posting and it doesnt talk about interfacing to PBX at all. Just to give more history here. It is currently being used hung off of a Nortel Meridian 1 system.(i think 21). We are putting in CCM 6 at this site and are tasked with paging integration also. I think the current set up is out of a CO trunk port. There page code is 811 if this helps any.
Any configuration examples you have would be greatly appreciated.
Hello Jason did you get my last response to you and did you ever come up with any ideas for me.
Thank you
Greg
Hi Greg,
Can you tell us what the Card Model # is on the Nortel? Then we can determine what to use with the ISR.
Rob
Rob it is a universal trunk card. and for clarification the nortel unit is coming out of production and we are moving to a Cisco callmanager platform. We are using the Cisco 2811 router as the voice gateway. In it we have both FXO and FXS option available. I have integrated paging into a situation like this before but I used an E&M module.
My only option with out redesign is fxo or fxs this is an after thought on this project. So any help would be greatly apprciated.
Greg
Hi Greg,
If you can;
Access the Nortel
Go into Load 20
Prt
PAG
The output may look like this;
REQ: PRT
TYPE: PAG
TN
CUST 0
DATE
PAGE
DES
TN x.x.x.x
TYPE PAG
CUST 0
RTMB 1 1
SIGL EAM
STRO IMM
SUPN NO
CLS UNR DTN CND WTA LPR
P10 VNL
DATE NO DATE
If it is set for E&M we will then know.
Hope this helps!
Rob
Thanks Rob I am assuming you want to know the Sigl type. If so that is LDR
However here is what everything it says
TN 004 0 11 07
Type Pag
cust 0
xtrk xut
Timp 600
BIMP 3com
RTMB 4 1
Sigl LDR
Stro IMM
Supn yes
Ast no
IAPG 0
CLS unr,dtn,cnd,wta,lpr,thfd, p10,ntc
Date No date
natc
DTC 001
Please let me know
Greg
Rob Huffman
Hi Greg,
OK, this is what I was afaid of. The problem here is that the Symetrix is not going to have any type of Telephony Interface (from spec sheet nicely supplied by Paolo) so we will need some "mid-span" type device. In the Nortel setup with the XUT set for Paging, when someone dialled 811 the Paging Card would answer and just "Bridge" the Audio over to the Symetrix. All the Smarts so to speak are in the Nortel Paging Card (Ring detection, Audio Cut-through etc) and the Symetrix is just a nice Amp.
Something like this;
http://www.camelectronics.com/botateacmo.html
Hope this helps!
Rob
Edit: Sorry, this would be used with an FXS Port :)
So Rob my options at this point is using an E&M card and do cut through or getting another device to integrate it.
Greg
Hi, I don't understand a thing of the Nortel config, but from Rob's explanation, I think an E&M correctly set would do, see this good document:
http://cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a008015094e.shtml
And you would be merrily paging.
Hi Guys,
Sorry, yes an E&M card should do the same thing :) I was thinking $$ pricing only. Comes from trying to save money whenever possible in the Campus environment (more for the Student programs!)
Take care,
Rob
All types of analog cards are the same price!
And for savers there's always the leading auction site :)
