SRST Devices not Expected
Feb 11th, 2008
CCM 4.2(3)
1760 12.1(3)T
SRST 3.1
In CallManager I have 24 phones in the SRST device pool. The other device pool is set to SRST-Disable.
When I simulate a CM failure (unplug the network cable) phones that are not part of the SRST DP are being registered and phones I wish to be enabled during failover are not.
Am I missing something somewhere?
Rob Huffman Mon, 02/11/2008 - 14:12
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ben,
No, you aren't missing anything here. Did you check that the Phones were reset after being assigned to the specific Device Pools. Or that if the changes were done at the Device Pool Level that you chose > Update>Reset Devices after making the changes?
Hope this helps!
Rob
benharned Tue, 02/12/2008 - 13:52
I'm sure I have, but I will definately try to reset them again and see what happens.
