3725 issue
Feb 11th, 2008
  • Bronze, 100 points or more
Hi all
my router keeps restarting after compressing the image and showing other common information.
I tried to boot it from ROMON but same result.
den I checked the dir flash: ,it shows me the IOS and boot flash:(IOS file)..but still keep restarting.
I think IOS is corrupted so should I use xmodem to send the IOS from pc to router or there is some other way.
nomair_83 Mon, 02/11/2008 - 21:52
Ya when I issued dir flash: then it shows me empty.
I tried again then it shows me the IOS file.
Paolo Bevilacqua Mon, 02/11/2008 - 13:48
  • Hall of Fame,
    Founding Member
Hi, usually if decompressing succeeds, the image file is not corrupted. However to reflash or boot from tftp, send a break from terminal then type tftpdnld, it will tell how to proceed to boot from tftp.
Hope this helps, pleas erate post if it does!
nomair_83 Mon, 02/11/2008 - 21:55
I think tftpdnld is only available in 3800 series..however I'll check this comnmand
thanx
Paolo Bevilacqua Tue, 02/12/2008 - 01:23
  • Hall of Fame,
    Founding Member
The command is available on almost all platforms since 1997.
