show ip add of clint on the report
Feb 11th, 2008
Dear Sir
I want to know there is any possibility which we have ability to see the client IP address on the report activity because already I can see the MAC address of the client but I want to see the IP address of the client I would be happy if you let me know your comment .
With best regards
Hamed yazdi
vkapoor5 Fri, 02/15/2008 - 13:46
Let me know in which product that you would like to see the ip address.
hamedyazdigss Sat, 02/16/2008 - 07:35
Dear Sir
Thanks for your kind reply. The equipments which I use are as follows:
1-Cisco Catalyst 2960 Series Switches
2-Cisco ACS version 4
I would like see the IP address of the client which connect to LAN through my switch on the ACS. It is considerable that the client authenticate via ACS.
With best regards
Hamed yazdi
