02-11-2008 04:39 PM - edited 03-15-2019 08:46 AM
Do you know how to view the access logs for CUCM 5.1.3 MLA?
Thank you,
Ricky
Solved! Go to Solution.
02-13-2008 08:06 PM
you would need to enable the following trace:
Cisco Role-based Security
and you can use RTMT to get them, this as with previous versions only shows who logged in, not what changes were made by the user
02-13-2008 08:06 PM
02-13-2008 11:19 PM
Thanks, i was able to view the logs now.
