configuring UCP 3.2 with IIS 5.0
Feb 11th, 2008
I IIS installef and working and I installed UCP 3.2 and I can connect to http://webserver/secure/login.htm but when I enter the username/password I get a message indicating the page address is incorrect and http 405 message. I went by the Installation and User Guide so I not sure why I am seeing the error message does anyone have a clue?
Gary
somishra Tue, 02/12/2008 - 05:31
  • Cisco Employee,
Gary,
This problem generally happens when you don't have the permissions on the virtual directories set correctly. So to fix it, launch your IIS MMC console, and for the properties of "secure" and "securecgi-bin"
directories, make sure the Execute permissions says "Scripts and Executables".
Hope this helps...
somishra
