Phones work but arent registered?
Feb 11th, 2008
This is a silly problem, something with RIS data collection probably, but I really have no idea.
The phone on my desk works just fine, i can pull the power out of it and it reloads just fine, but when I look in Callmanager (4.2(1)) it and all the other phones are Status Not Found. Everything seems to work just find but no IP addresses are displayed and everything says status not found.
Anyone have any advice before I have to call TAC about it?
edit:
I checked this
http://www.ciscotaccc.com/voice/showcase?case=K14234177
but 1) I dont see the "Real-time Information Service is not responding. Check to make sure the service is running." message
and 2) restarting the RIS services either from Control Center or the MMC Services or just outright rebooting the cluster isnt helping
Jaime Valencia Tue, 02/12/2008 - 08:50
instead of rebooting the server try this:
restart Cisco tomcat from MMC services
open a cmd prompt and type
iisreset until iis resets successfully
then restart RIS from control center
