Cvoice simulation
Feb 12th, 2008
Hi, i want to pass the Cvoice exam, i wanna know how many simulation (LAB) there is in the exam, because im my testking i have only one simulation.. Thanks...
Overall Rating: 3 (2 ratings)
davetucker Tue, 02/12/2008 - 02:33
  • Bronze, 100 points or more
I recently passed my CVOICE exam and there were apporx 2/3 simulation questions. You will most likely be asked to do one or more of the following, so make sure that you are confident with the exam topics
http://www.cisco.com/web/learning/le3/current_exams/642-432.html
- Configure dial-peer settings for VoIP or POTs
- Configure POTs ports (FXS and FXO)
- Configure E&M
- Explain default dial-peer
- Explain matching inbound/outbound dial peers
- Configure hunt groups
- Explain digit collection, consumptions and manipulations
- Configure gateway/gatekeeper
- Configure call signalling
Hope this helps, if so please rate
Dave
a.rayen83 Tue, 02/12/2008 - 02:54
Hii, Thanks for the information, but in another Forum there is a lot of persons who has passed the exam but they had only ne simulation (+9T), Dave i mean with a simulation the use of the terminal and configure, but not a QCM simulation. i wait ur confirmation et thanks a lot for the information
davetucker Tue, 02/12/2008 - 03:04
Yes I definately had at least 2 simulation questions. From what I can remember I had one which was completing an H323 gateway config that could not register with the gatekeeper and one which was configuring an FXS port. I might just have been unlucky.
Dave
a.rayen83 Tue, 02/12/2008 - 03:41
Hi Dave,
i think that have been very unluckly :), please can i know when u hav pass ur exam, and in what kind of center (prometric or vue). Thanks
davetucker Tue, 02/12/2008 - 03:52
I passed in May 07 at a Prometric test centre.
Dave
omar.elmohri Tue, 02/12/2008 - 03:57
Goodday every one,
Prometric, you means that it's different from actuel test, because now only Pearson VUE exists.
davetucker Tue, 02/12/2008 - 04:02
Guys,
One thing is to remember the exams are exactly the same whether tested at a Prometric or a VUE centre. Although I booked through Prometric my local test centre is both VUE and Promteric certified. The last 2 exams I've sat were booked through VUE since Cisco has changed alliegences.
omar.elmohri Tue, 02/12/2008 - 04:43
Really !
Because I saw some differences between than, and that was when I passed my CCNA in about one year and a half.
I passed INTRO and it was near to TestKing and ICND was near the Pass4Sure
dlillis65 Tue, 02/19/2008 - 19:53
I have a suggestion. Why don't you learn the material and then you dont have to worry about how many simulations there are. If you REALLY know the material you will pass.
