Feb 12th, 2008
Need your help for giving route.
We are having one router where the Fastethernet is configured with
Now Iam connecting another router to the switch and given pool ip.While giving route it is not accepting.
pls suggest wht can be done.
s.arunkumar Tue, 02/12/2008 - 03:49
what error are u getting..
I think the command is not correct
its "ip route"
Rick Morris Wed, 02/13/2008 - 12:39
What I gather is this.
You have a LAN connected to FastEthernet with IP
Traffic comes in from this interface and you are then telling your traffic to go back through the same interface it just came from?
Is there a reason you are doing that?
Where are you wanting to send the traffic from that interface?
The static route is like the traffic cop for traffic. It specifically states where to send the traffic.
Need more info, but as stated in your post it will not work.
