nat (interface) 0 access-list 100 command erase automatically after reboot
Feb 12th, 2008
I have used nat0 command to transfer outside ip address directly to inside users.But whenever my pix reboots
nat (Interface) access-list 100 command erase automatically& i will have to reconfigure it every time by changing access list name .Please guide me to resolve it permentaly.
abinjola Tue, 02/12/2008 - 05:38
  • Cisco Employee,
you make this configuration via ASDM ? are those host/network being named ?
what version you running ?
manik.palekar Wed, 02/13/2008 - 05:19
hi ..
i did it by console..version 7.1 is used.i didnt get your 2nd point.
sample config...
# nat (inside) 0 access-list 100
# access-list 100 permit ip any 145.xx.xx.xx
Thanks...
abinjola Wed, 02/13/2008 - 06:51
  • Cisco Employee,
looks like a bug to me..is upgrade possible for you ?
cisco24x7 Wed, 02/13/2008 - 07:09
  • Silver, 250 points or more
That's the price you pay for running Early
Deployment (ED) code. These are 'beta' code
as far as I am concerned.
The question is: is downgrade possible for you?
You should be running 7.0(7) because it is
General Deployment (GD) code.
CCIE Security
abinjola Wed, 02/13/2008 - 07:21
  • Cisco Employee,
I would suggest for an upgrade to 7.2.3 which is quite stable and was an end to all the 7.2.x interims.
cisco24x7 Wed, 02/13/2008 - 07:45
Is version 7.2(3) ED or GD?
I would STRONGLY recommed staying from any
ED code. They are just not stable.
my 2c.
abinjola Wed, 02/13/2008 - 08:04
  • Cisco Employee,
hello Requester..7.0.3 doesn't support many features like U-turning of clear text traffic,PPOE,and many other...you are safe to to go 7.2.3 as this was a dead end for all interims on 7.2.x and has been quite stable...if you want to go to 7.0.7 (GD) you will loose many feature set..choice is yours.
