Is CiscoWorks LMS 3.0 64 bits?
Feb 12th, 2008
Dear all,
A few questions came up to me during investment plan CiscoWorks:
- Is CiscoWorks an "64 bits" application?
- The quad-core cpu's are not mentioned in the documentation! Is this CPU not supported?
- The SunSparc CPU's, which mentioned in the HW requirements, are only supported CPU's?
-Aryan
Overall Rating: 5 (1 ratings)
derek.sizeland Tue, 02/12/2008 - 04:55
Aryan,
I can answer your first question, currently CiscoWorks is 32 bit only.
Are you planning to use Windows or Solaris?
ahajivandi Tue, 02/12/2008 - 06:26
Derek,
Thanks for your reply. I have proposed Solaris 10, used right motivation.
-Aryan
frederick.w.moore Wed, 02/13/2008 - 07:54
I was told by TAC that LMS 3.0 is 32-bit and LMS 3.0.1 (Dec 2007 update) is 64-bit. You first install 3.0 on 2003 Sever 64-bit and then immediately install the Dec 2007 update. Then you can run the program.
Joe Clarke Wed, 02/13/2008 - 09:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is incorrect. LMS is composed of 32-bit binaries, even in LMS 3.0.1. However, in LMS 3.0.1 we support running LMS on 64-bit Windows. The binaries still have 32-bit memory limitations, but the configuration is supported. We have supported running 32-bit LMS on a 64-bit Solaris kernel since Solaris became 64-bit.
Joe Clarke Wed, 02/13/2008 - 10:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No comparison testing was done between the two architectures. Given that we are not taking advantage of 64-bit addresses, I don't anticipate much of a gain in either performance or stability.
dainat-bis Thu, 02/14/2008 - 01:41
Unanswered until now is if the quad-core ( Intel Core2 Quad or AMD PhenomX4 ) cpu's are supported or not for LMS3.0.1.
Joe Clarke Thu, 02/14/2008 - 08:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, they are supported.
Martin Ermel Mon, 03/03/2008 - 08:41
  • Blue, 1500 points or more
to have LMS running on 64-bit Windows, is it necessary to have the LMS 3.0.1 DVDs (binaries that include the dec2007 update) or is it possible to have a 64-bit Windows installation, install LMS 3.0 and then install all the latest patches to get LMS 3.0.1?
Joe Clarke Mon, 03/03/2008 - 09:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can install LMS 3.0 on 64-bit Windows, reboot, then immediately upgrade to LMS 3.0.1, and reboot again.
