VPN Concentrator to Watchguard Phase 1 fails
Feb 12th, 2008
I am trying to setup a lan-lan between our VPNConcentrator and a Watchguard firewall it is failing on Phase 1
Phase 1 failure against global IKE proposal # 1:
Mismatched attr types for class Auth Method:
Rcv'd: Preshared Key
Cfg'd: XAUTH with Preshared Key (Initiator authenticated)
I am confused as to where the XAUTH error lies is it my end or the remote end?
Roger
Richard Burts Mon, 02/18/2008 - 10:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Roger
The error message is indicating that XAUTH is configured on your side and not configured on the other side. It can work if both sides are configured for XAUTH or if both sides are not configured for XAUTH. The suggestion from Theo to check and make sure that the key configured on both sides is the same is a good suggestion. But I do not believe that you have gotten to that stage yet.
Rick
cisco24x7 Mon, 02/18/2008 - 11:29
  • Silver, 250 points or more
LAN-2-LAN IPSec VPN does NOT require XAUTH.
XAUTH is remote access VPN, NOT L2L vpn.
To fix this, go into the VPN concentrator, look at phase I proposal that is attached
to this VPN tunnel and you will see that
it has XAUTH associated to it. Click on the
drop down menu and select "no xauth" and
it will work after that.
Easy right?
CCIE Security
