Richard Burts Tue, 02/12/2008 - 08:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Brian
For the console of a 3005 VPN Concentrator you want a straight through serial (9 pin) cable - not the rolled cable that is common on IOS devices.
But I am wondering if you are talking about the console since the rest of the title of your question indicates E/FE. Perhaps you can clarify what the question is about?
Rick
cisco24x7 Tue, 02/12/2008 - 09:38
  • Silver, 250 points or more
1- Use Teraterm or SecureCRT terminal app,
2- Connect a DB-9 connector to the the console
port of the VPNc,
3- Connect a DB-9 connector to the COM1 port
of the PC where Teraterm or SecurCRT runs,
4- set the setting to 9600/8/1/hardware,
5- connect one end of the ethernet cable to
the db-9 connected to the PC. The other end
should be connected to the DB-9 connected
to the VPNc.
Now you will get a login prompt
Easy right?
CCIE Security
